Salta al contenuto principale
Dell Inspiron N4110 Motherboard Replacement
Cosa ti serve
  1. Dell Inspiron N4110 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Motherboard Replacement: passo 2, immagine 1 di 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Motherboard Replacement: passo 3, immagine 1 di 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Motherboard Replacement, Fan: passo 4, immagine 1 di 2 Dell Inspiron N4110 Motherboard Replacement, Fan: passo 4, immagine 2 di 2
    • Remove the 10 2.5x5 mm screws from the base of the laptop.
  5. Dell Inspiron N4110 Motherboard Replacement: passo 5, immagine 1 di 1
    • Unscrew the final 2.5x5 mm screw attached to the cover.
    • This screw is "captive" and does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  6. Dell Inspiron N4110 Motherboard Replacement: passo 6, immagine 1 di 2 Dell Inspiron N4110 Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the cover from the laptop.
  7. Dell Inspiron N4110 Motherboard Replacement: passo 7, immagine 1 di 2 Dell Inspiron N4110 Motherboard Replacement: passo 7, immagine 2 di 2
    • Unscrew the 2.5x5 mm screw inside the RAM compartment.
  8. Dell Inspiron N4110 Motherboard Replacement: passo 8, immagine 1 di 2 Dell Inspiron N4110 Motherboard Replacement: passo 8, immagine 2 di 2
    • Remove the disk drive from the side of the computer.
    • There is no need to press the button, the drive will come out.
  9. Dell Inspiron N4110 Motherboard Replacement: passo 9, immagine 1 di 2 Dell Inspiron N4110 Motherboard Replacement: passo 9, immagine 2 di 2
    • Unscrew the two 2x3 mm screws inside the disk drive compartment.
  10. Dell Inspiron N4110 Motherboard Replacement: passo 10, immagine 1 di 3 Dell Inspiron N4110 Motherboard Replacement: passo 10, immagine 2 di 3 Dell Inspiron N4110 Motherboard Replacement: passo 10, immagine 3 di 3
    • Flip the computer over, and open the laptop.
    • Use a plastic opening tool to begin to remove the keyboard.
    • Use your hands to finish separating the keyboard from the laptop.
    • This can be a bit challenging, but it will come loose.
  11. Dell Inspiron N4110 Motherboard Replacement: passo 11, immagine 1 di 1
    • Lift the black clip from the tan connection for the keyboard.
    • Pull the the connection away from the clip.
    • Move the keyboard away from the laptop.
    • With the keyboard removed, consider this opportunity to more freely clean it out with some compressed air.
  12. Dell Inspiron N4110 Motherboard Replacement: passo 12, immagine 1 di 1
    • Lift the black clips from the tan connections for all 3 locations marked.
    • Remove the connections from the clips.
  13. Dell Inspiron N4110 Motherboard Replacement: passo 13, immagine 1 di 1
    • Unscrew the five 2.5x5 mm screws.
  14. Dell Inspiron N4110 Motherboard Replacement: passo 14, immagine 1 di 2 Dell Inspiron N4110 Motherboard Replacement: passo 14, immagine 2 di 2
    • Use plastic opening tools to remove base cover.
    • Use your hands to fully remove cover from the base.
    • This may be difficult, but it is possible.
  15. Dell Inspiron N4110 Motherboard Replacement: passo 15, immagine 1 di 1
    • Disconnect the two cables that connect the speaker and the fan.
    • These can just be pulled out, they do not have clips.
  16. Dell Inspiron N4110 Motherboard Replacement: passo 16, immagine 1 di 1
    • Disconnect the ribbon cable over the screw to reveal it. Flip up the latch and pull gently on the ribbon to remove it from the connector.
    • Unscrew the 2.5x5 mm screw from the fan.
  17. Dell Inspiron N4110 Motherboard Replacement: passo 17, immagine 1 di 2 Dell Inspiron N4110 Motherboard Replacement: passo 17, immagine 2 di 2
    • Pull up and remove the fan from the laptop.
  18. Dell Inspiron N4110 Motherboard Replacement, Motherboard: passo 18, immagine 1 di 1
    • Unscrew the six 2.5x5mm screws from the motherboard.
    • Note that this screw may be "retained" by the loop at the end of the grounding wire.
  19. Dell Inspiron N4110 Motherboard Replacement: passo 19, immagine 1 di 2 Dell Inspiron N4110 Motherboard Replacement: passo 19, immagine 2 di 2
    • Disconnect the black and yellow cable from the motherboard.
  20. Dell Inspiron N4110 Motherboard Replacement: passo 20, immagine 1 di 1
    • Begin to separate the motherboard from the laptop
    • Pull up to separate from the other internal pieces, and then pull to the right away from the case
  21. Dell Inspiron N4110 Motherboard Replacement: passo 21, immagine 1 di 1
    • Remove the final cable from the motherboard
    • This will allow the motherboard to fully come out of the computer
    • When reinstalling motherboard, ensure the two connectors are precisely aligned with the daughterboard below. If slightly misaligned, you may bend the pins on the daughterboard connector.
Conclusione
Altre 2 persone hanno completato questa guida.
Olivia
Membro da: 03/20/18
773 Reputazione
3 Guide realizzate
2 Commenti
After pulling off the battery, the step to remove the four M2x3 mm screws was forgotten. Please update the guide.
apocalypse612 - Replica
Hi my Friend, can you send me a picture in this zone, i need change a transistor smd to controller the battery charged.
The transistor is near to connector display
Sorry for my English, I'm a uruguayan thanks
Agustin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 41
Tutti i Tempi: 2,650
