Salta al contenuto principale
Dell Inspiron N4010 Top Cover Replacement
Cosa ti serve
  1. Dell Inspiron N4010 Top Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Top Cover Replacement: passo 2, immagine 1 di 2 Dell Inspiron N4010 Top Cover Replacement: passo 2, immagine 2 di 2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Top Cover Replacement: passo 3, immagine 1 di 1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Top Cover Replacement, Keyboard: passo 4, immagine 1 di 3 Dell Inspiron N4010 Top Cover Replacement, Keyboard: passo 4, immagine 2 di 3 Dell Inspiron N4010 Top Cover Replacement, Keyboard: passo 4, immagine 3 di 3
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Top Cover Replacement: passo 5, immagine 1 di 1
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Top Cover Replacement: passo 7, immagine 1 di 2 Dell Inspiron N4010 Top Cover Replacement: passo 7, immagine 2 di 2
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Top Cover Replacement: passo 8, immagine 1 di 2 Dell Inspiron N4010 Top Cover Replacement: passo 8, immagine 2 di 2
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Top Cover Replacement: passo 9, immagine 1 di 2 Dell Inspiron N4010 Top Cover Replacement: passo 9, immagine 2 di 2
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
  9. Dell Inspiron N4010 Top Cover Replacement, Top Cover: passo 10, immagine 1 di 2 Dell Inspiron N4010 Top Cover Replacement, Top Cover: passo 10, immagine 2 di 2
    • Remove the indicated 5.7mm screws.
    • Remove the smaller 3mm screws from underneath the battery compartment.
  10. Dell Inspiron N4010 Top Cover Replacement: passo 11, immagine 1 di 2 Dell Inspiron N4010 Top Cover Replacement: passo 11, immagine 2 di 2
    • With a plastic spudger, pry away the silver top cover from the black casing.
    • Move the tool to the right and left along the seams to fully disconnect the cover.
  11. Dell Inspiron N4010 Top Cover Replacement: passo 12, immagine 1 di 1
    • Disconnect the indicated ribbon cables underneath where the keyboard sits.
  12. Dell Inspiron N4010 Top Cover Replacement: passo 13, immagine 1 di 1
    • Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right
Conclusione
USF Tampa, Team S13-G5, Boczar Fall 2017 Membro di USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 704
