Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Replacing the speakers can fix possible hardware-related sound issues
  1. Make sure the laptop is not plugged into any wall outlets or the charger
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. While holding the left-hand switch to the left position, pull the battery away from the laptop. While holding the left-hand switch to the left position, pull the battery away from the laptop.
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. The battery is now fully removed and the laptop will not power on without it.
    • The battery is now fully removed and the laptop will not power on without it.
  4. Using the #0 Philips head, unscrew the indicated screw. Carefully pull  the RAM cover up and away. Carefully pull  the RAM cover up and away.
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away. Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop. Be careful not to put stress on the ribbon cable below.
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Kit cacciaviti Manta
    112 punte per ogni riparazione.
    Upgrade Your Toolbox
  9. Carefully unclip the ribbon cable by tipping the keyboard towards the screen. The keyboard is now completely disconnected.
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
  10. Remove the indicated 5.7mm screws. Remove the smaller 3mm screws from underneath the battery compartment.
    • Remove the indicated 5.7mm screws.
    • Remove the smaller 3mm screws from underneath the battery compartment.
  11. With a plastic spudger, pry away the silver top cover from the black casing. Move the tool to the right and left along the seams to fully disconnect the cover.
    • With a plastic spudger, pry away the silver top cover from the black casing.
    • Move the tool to the right and left along the seams to fully disconnect the cover.
  12. Disconnect the indicated ribbon cables underneath where the keyboard sits.
    • Disconnect the indicated ribbon cables underneath where the keyboard sits.
  13. Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right
    • Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right
  14. Peel back the yellow tape to expose the ribbon connector. Unplug the ribbon cable from the motherboard.
    • Peel back the yellow tape to expose the ribbon connector.
    • Unplug the ribbon cable from the motherboard.
  15. Unplug the 3-wire connector from the motherboard.
    • Unplug the 3-wire connector from the motherboard.
  16. Unscrew the indicated 5.6mm screws with the #0 Phillips Head Screwdriver.
    • Unscrew the indicated 5.6mm screws with the #0 Phillips Head Screwdriver.
  17. Remove the fan from the device.
    • Remove the fan from the device.
  18. Unscrew the two screws on the right hand speaker with the #0 Phillips Head. Unplug the speaker connector from the motherboard.
    • Unscrew the two screws on the right hand speaker with the #0 Phillips Head.
    • Unplug the speaker connector from the motherboard.
  19. Reaching under the daughter board, disconnect the connector.
    • Reaching under the daughter board, disconnect the connector.
    • It will be under the board in the area indicated.
  20. Unscrew the indicated 5.6mm screws with a Phillips #0 screwdriver.
    • Unscrew the indicated 5.6mm screws with a Phillips #0 screwdriver.
  21. The motherboard can now be removed by pulling upwards, tilting it to the left of the laptop until the connectors clear the body of the laptop.
    • The motherboard can now be removed by pulling upwards, tilting it to the left of the laptop until the connectors clear the body of the laptop.
  22. Unscrew the (2) two 3.6mm Phillips head screws with the #0 Phillips head.
    • Unscrew the (2) two 3.6mm Phillips head screws with the #0 Phillips head.
  23. Remove the speakers from the device.
    • Remove the speakers from the device.
Conclusione
USF Tampa, Team S13-G5, Boczar Fall 2017 Membro di USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 88
