Salta al contenuto principale
Dell Inspiron Mini 1012: Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron Mini 1012: Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the battery
  2. Dell Inspiron Mini 1012: Keyboard Replacement: passo 2, immagine 1 di 1
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Dell Inspiron Mini 1012: Keyboard Replacement: passo 3, immagine 1 di 2 Dell Inspiron Mini 1012: Keyboard Replacement: passo 3, immagine 2 di 2
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  4. Dell Inspiron Mini 1012: Keyboard Replacement: passo 4, immagine 1 di 1
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Ohio State, Team 1-1, Buehl Fall 2014 Membro di Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 Membri
4 Guide realizzate
1Commento della guida
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 3,408
