Salta al contenuto principale
Dell Inspiron Mini 1012 Screen Replacement
Cosa ti serve
  1. Dell Inspiron Mini 1012 Screen Replacement, Screen: passo 1, immagine 1 di 3 Dell Inspiron Mini 1012 Screen Replacement, Screen: passo 1, immagine 2 di 3 Dell Inspiron Mini 1012 Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Remove the battery from the device for safety. Slide the two tabs on the bottom of the computer to the unlocked position, and gently lift up the battery.
    • Remove the two rubber pieces at the bottom of the screen and remove the screws located behind them.
    • Carefully remove the plastic casing from the device.
  2. Dell Inspiron Mini 1012 Screen Replacement: passo 2, immagine 1 di 3 Dell Inspiron Mini 1012 Screen Replacement: passo 2, immagine 2 di 3 Dell Inspiron Mini 1012 Screen Replacement: passo 2, immagine 3 di 3
    • Remove the four screws on each corner of the screen. Then remove the screws located on the side of the screen.
    • Carefully unplug the ribbon on the back of the screen.
  3. Dell Inspiron Mini 1012 Screen Replacement: passo 3, immagine 1 di 3 Dell Inspiron Mini 1012 Screen Replacement: passo 3, immagine 2 di 3 Dell Inspiron Mini 1012 Screen Replacement: passo 3, immagine 3 di 3
    • Place the new screen onto the device and plug the ribbon in.
    • Replace the screws on the side of the screen.
  4. Dell Inspiron Mini 1012 Screen Replacement: passo 4, immagine 1 di 3 Dell Inspiron Mini 1012 Screen Replacement: passo 4, immagine 2 di 3 Dell Inspiron Mini 1012 Screen Replacement: passo 4, immagine 3 di 3
    • Snap on the plastic screen cover and replace the two screws and the rubber pieces at the bottom of the screen.
    • Turn the computer over and put the battery back in.
Conclusione
To reassemble your device, follow guide instructions.
Altre 2 persone hanno completato questa guida.
sabinabarajas
Membro da: 10/17/15
372 Reputazione
3 Guide realizzate
Gateway, Team 2-2, Kuhn Fall 2015 Membro di Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 Membro
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,351
