Remove the battery
  • Remove the battery
Aggiungi Commento
Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
Aggiungi Commento
  • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
  • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
  • Gently lift up the keyboard starting at the top of the frame
  • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
Aggiungi Commento
  • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
Aggiungi Commento
  • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Aggiungi Commento
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Marie K Bordley
Membro da: 30/09/2014
177 Reputazione
2 Guide realizzate
Ohio State, Team 1-1, Buehl Fall 2014 Membro di Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 Membri
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 57
Tutti i Tempi: 2,509
