Salta al contenuto principale
Dell Inspiron Mini 10 Touchpad Replacement
Cosa ti serve
  1. Dell Inspiron Mini 10 Touchpad Replacement, Battery: passo 1, immagine 1 di 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Touchpad Replacement: passo 2, immagine 1 di 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: passo 3, immagine 1 di 2 Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: passo 3, immagine 2 di 2
    • Using a spudger, gently pry the palm rest off of the palm rest bracket.
    • Carefully remove the palm rest from the computer base to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Touchpad Replacement: passo 4, immagine 1 di 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Touchpad Replacement: passo 5, immagine 1 di 3 Dell Inspiron Mini 10 Touchpad Replacement: passo 5, immagine 2 di 3 Dell Inspiron Mini 10 Touchpad Replacement: passo 5, immagine 3 di 3
    • Turn the palm rest assembly over.
    • Remove the four 3mm Phillips 0 screws that secure the touchpad module to the palm rest.
    • Gently lift the copper and silver foil squares on the touchpad.
    • Remove the touchpad from the palm rest.
Conclusione
Angela Wild
Membro da: 10/26/16
104 Reputazione
1 Guida realizzata
UW Tacoma, Team 1-4, Rose Fall 2016 Membro di UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 619
