Salta al contenuto principale
Dell Inspiron Mini 10 Palm Rest Replacement
Cosa ti serve
  1. Dell Inspiron Mini 10 Palm Rest Replacement, Battery: passo 1, immagine 1 di 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Palm Rest Replacement: passo 2, immagine 1 di 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Palm Rest Replacement, Palm Rest: passo 3, immagine 1 di 1
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Palm Rest Replacement: passo 4, immagine 1 di 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
Conclusione
Bariso Shuba
Membro da: 10/26/16
270 Reputazione
3 Guide realizzate
UW Tacoma, Team 1-4, Rose Fall 2016 Membro di UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 314
