Salta al contenuto principale
Dell Inspiron M5110 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron M5110 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Keyboard Replacement: passo 3, immagine 1 di 1
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Keyboard Replacement: passo 5, immagine 1 di 1
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Keyboard Replacement: passo 6, immagine 1 di 1
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Keyboard Replacement: passo 7, immagine 1 di 1
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Keyboard Replacement: passo 8, immagine 1 di 1
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Keyboard Replacement: passo 9, immagine 1 di 1
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
Conclusione
Cody Flynn
Membro da: 10/18/16
331 Reputazione
4 Guide realizzate
UMass Dartmouth, Team 4-3, Catania Fall 2016 Membro di UMass Dartmouth, Team 4-3, Catania Fall 2016
UMASSD-CATANIA-F16S4G3
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 263
