Introduzione
In this guide, we will be showing you how to remove and replace the Memory Modules.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  1. Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
    • Remove the memory module from the memory-module connector.
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linea Traguardo
Terrence15
Membro da: 18/12/2017
70.168 Reputazione
442 Guide realizzate
Informative Technologies Inc. Membro di Informative Technologies Inc.
Community
15 Membri
925 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 8
