Salta al contenuto principale
Dell Inspiron M5010 LCD Screen Replacement
Cosa ti serve
  1. Dell Inspiron M5010 LCD Screen Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron M5010 LCD Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 LCD Screen Replacement, Remove keyboard retaining screw: passo 2, immagine 1 di 1
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 LCD Screen Replacement: passo 3, immagine 1 di 3 Dell Inspiron M5010 LCD Screen Replacement: passo 3, immagine 2 di 3 Dell Inspiron M5010 LCD Screen Replacement: passo 3, immagine 3 di 3
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
  6. Dell Inspiron M5010 LCD Screen Replacement, Palm Rest: passo 6, immagine 1 di 1
    • Flip the laptop, so the bottom of the laptop is facing up.
    • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
  7. Dell Inspiron M5010 LCD Screen Replacement: passo 7, immagine 1 di 2 Dell Inspiron M5010 LCD Screen Replacement: passo 7, immagine 2 di 2
    • Flip the laptop back over, so that the top of the laptop is facing up.
    • Open the laptop.
    • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
  8. Dell Inspiron M5010 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
  9. Dell Inspiron M5010 LCD Screen Replacement: passo 9, immagine 1 di 3 Dell Inspiron M5010 LCD Screen Replacement: passo 9, immagine 2 di 3 Dell Inspiron M5010 LCD Screen Replacement: passo 9, immagine 3 di 3
    • Carefully unsnap and remove the palm rest.
    • Place your fingers inside the large circle in the lower right corner to get a good grip.
  10. Dell Inspiron M5010 LCD Screen Replacement, LCD Screen: passo 10, immagine 1 di 1
    • Flip the laptop over to its backside.
    • Using the Phillips #000 Screwdriver remove the six indicated 6.0mm Phillips #000 screws.
  11. Dell Inspiron M5010 LCD Screen Replacement: passo 11, immagine 1 di 1
    • Flip the laptop over to its front side and open the laptop.
    • Remove the four 6.0mm Phillips #000 screws holding the screen to the base of the laptop using a Phillips #000 Screwdriver.
  12. Dell Inspiron M5010 LCD Screen Replacement: passo 12, immagine 1 di 2 Dell Inspiron M5010 LCD Screen Replacement: passo 12, immagine 2 di 2
    • Pull up both the black and white chords to completely detach the screen.
  13. Dell Inspiron M5010 LCD Screen Replacement: passo 13, immagine 1 di 2 Dell Inspiron M5010 LCD Screen Replacement: passo 13, immagine 2 di 2
    • Lift the screen from the base of the laptop.
  14. Dell Inspiron M5010 LCD Screen Replacement: passo 14, immagine 1 di 2 Dell Inspiron M5010 LCD Screen Replacement: passo 14, immagine 2 di 2
    • Use a spudger to separate and remove the plastic frame on the front of the screen.
  15. Dell Inspiron M5010 LCD Screen Replacement: passo 15, immagine 1 di 2 Dell Inspiron M5010 LCD Screen Replacement: passo 15, immagine 2 di 2
    • Use a Phillips #000 Screwdriver to remove the 8 6.0mm Phillips #000 screws marked in the image.
  16. Dell Inspiron M5010 LCD Screen Replacement: passo 16, immagine 1 di 1
    • Lift LCD screen from the plastic frame.
  17. Dell Inspiron M5010 LCD Screen Replacement: passo 17, immagine 1 di 3 Dell Inspiron M5010 LCD Screen Replacement: passo 17, immagine 2 di 3 Dell Inspiron M5010 LCD Screen Replacement: passo 17, immagine 3 di 3
    • Flip LCD screen over to view the backside.
    • Lift brown tab in the middle of the screen and pull to remove the entire piece.
  18. Dell Inspiron M5010 LCD Screen Replacement: passo 18, immagine 1 di 2 Dell Inspiron M5010 LCD Screen Replacement: passo 18, immagine 2 di 2
    • Use a Phillips #000 Screwdriver to remove the four screws indicated (two on each side).
    • Pull metal frames away from LCD screen.
    • The metal frame on each side is pulled away separately, so make sure to make note of which side each one came from.
Conclusione
April Poucher
Membro da: 10/13/14
1.164 Reputazione
10 Guide realizzate
Clemson, Team 1-5, Benson Fall 2014 Membro di Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 Membri
11 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,110
