Salta al contenuto principale
Dell Inspiron M5010 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron M5010 Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron M5010 Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 Keyboard Replacement, Remove keyboard retaining screw: passo 2, immagine 1 di 1
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 Keyboard Replacement: passo 3, immagine 1 di 3 Dell Inspiron M5010 Keyboard Replacement: passo 3, immagine 2 di 3 Dell Inspiron M5010 Keyboard Replacement: passo 3, immagine 3 di 3
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 Keyboard Replacement: passo 4, immagine 1 di 1
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 Keyboard Replacement: passo 5, immagine 1 di 1
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
Conclusione
April Poucher
Membro da: 10/13/14
1.164 Reputazione
10 Guide realizzate
Clemson, Team 1-5, Benson Fall 2014 Membro di Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 722
