Salta al contenuto principale
Dell Inspiron M5010 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron M5010 Display Assembly Replacement, Remove the Screws: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over and remove the two screws.
  2. Dell Inspiron M5010 Display Assembly Replacement, Disconnect the Cables: passo 2, immagine 1 di 1
    • Disconnect the Mini-Card antenna cables from the Mini-Card.
  3. Dell Inspiron M5010 Display Assembly Replacement, Disconnect the Display Cable: passo 3, immagine 1 di 1
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  4. Dell Inspiron M5010 Display Assembly Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Remove the four screws (two on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron M5010 Display Assembly Replacement, Lifting the Display Assembly: passo 5, immagine 1 di 1
    • Lift and remove the display assembly out of the computer base.
  6. Dell Inspiron M5010 Display Assembly Replacement, Placing the Display Assembly: passo 6, immagine 1 di 1
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron M5010 Display Assembly Replacement, Route the Display Cable: passo 7, immagine 1 di 1
    • Route the display cable into the routing guide and connect the cable to the connector on the system board.
  8. Dell Inspiron M5010 Display Assembly Replacement, Connecting the Mini-Card Antenna Cables: passo 8, immagine 1 di 1
    • Connect the Mini-Card antenna cables to the connectors on the Mini- Card.
  9. Dell Inspiron M5010 Display Assembly Replacement, Replace the Screws: passo 9, immagine 1 di 1
    • Turn the computer over and replace the two screws at the bottom of the computer.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.091 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.985 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 179
