Cosa ti serve
Slide both arrow tabs towards the outer edge of the computer to release the battery.
Remove Keyboard retaining screw from bottom of laptop.
Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
Flip the laptop, so the bottom of the laptop is facing up.
Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
Flip the laptop over to its backside.
Using the Phillips #000 Screwdriver remove the six indicated 6.0mm Phillips #000 screws.
Using a Phillips #000 Screwdriver, remove the indicated 6.0 mm screw on the left side of the camera.
Pull the tab and release the ribbon on the right side of the camera.
Pull the camera away from the plastic frame.
