Salta al contenuto principale
Dell Inspiron E1705 Upper Case and Screen Replacement
Cosa ti serve
  1. Dell Inspiron E1705 Upper Case and Screen Replacement, Upper Case and Screen: passo 1, immagine 1 di 1
    • Use a spudger to remove the six rubber nibs and 2 plastic pieces on the bezel of the display.
    • Remove the eight Phillips #0 screws hidden under the rubber nibs and plastic pieces.
  2. Dell Inspiron E1705 Upper Case and Screen Replacement: passo 2, immagine 1 di 2 Dell Inspiron E1705 Upper Case and Screen Replacement: passo 2, immagine 2 di 2
    • Pry the plastic bezel from the back plate using a plastic opening tool.
    • Remove the plastic bezel entirely and set it aside.
  3. Dell Inspiron E1705 Upper Case and Screen Replacement: passo 3, immagine 1 di 2 Dell Inspiron E1705 Upper Case and Screen Replacement: passo 3, immagine 2 di 2
    • Remove the 4 screws along the left and right sides of the screen. There are 8 screws in total.
  4. Dell Inspiron E1705 Upper Case and Screen Replacement: passo 4, immagine 1 di 2 Dell Inspiron E1705 Upper Case and Screen Replacement: passo 4, immagine 2 di 2
    • Use the spudger to separate the screen from the back case.
    • Hold the screen in one hand and tilt the back case away from you.
    • The screen is connected to the back case by two leads.
  5. Dell Inspiron E1705 Upper Case and Screen Replacement: passo 5, immagine 1 di 2 Dell Inspiron E1705 Upper Case and Screen Replacement: passo 5, immagine 2 di 2
    • Remove the two leads from the screen. They will stay connected to the computer.
    • Do not touch the white tape on your replacement monitor.
    • Remove the screen carefully.
Conclusione
Altre 9 persone hanno completato questa guida.
Cal Poly, Team 22-5, Maness Fall 2010 Membro di Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 7,015
