Salta al contenuto principale
Dell Inspiron E1705 Optical Drive Replacement
Cosa ti serve
  1. Dell Inspiron E1705 Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Optical Drive Replacement: passo 2, immagine 1 di 2 Dell Inspiron E1705 Optical Drive Replacement: passo 2, immagine 2 di 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 1
    • Locate and remove the screw shown
    • It is labeled with a lock symbol
  4. Dell Inspiron E1705 Optical Drive Replacement: passo 4, immagine 1 di 2 Dell Inspiron E1705 Optical Drive Replacement: passo 4, immagine 2 di 2
    • Use the screwdriver to gently push the optical drive out
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 22-5, Maness Fall 2010 Membro di Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,926
