Salta al contenuto principale
Dell Inspiron E1505 Battery Replacement
  1. Dell Inspiron E1505 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Before any work can be done ensure that the laptop is powered off.
    • Use either the power button on the computer or issue a shutdown from the operating system.
    • Once the device is off place the laptop on a flat surface and flip it so that the bottom is facing upwards.
  2. Dell Inspiron E1505 Battery Replacement: passo 2, immagine 1 di 1
    • Locate the battery release switch on the bottom of the laptop.
    • Once located slide the switch into the unlock position.
  3. Dell Inspiron E1505 Battery Replacement: passo 3, immagine 1 di 1
    • Locate the “lip” on the laptop to lift the battery outside of the compartment.
    • Once the battery is out, you will be able to find the replacement part number in order to purchase a new battery.
  4. Dell Inspiron E1505 Battery Replacement: passo 4, immagine 1 di 1
    • Once the new battery has been acquired take the battery and place it in the empty battery slot.
    • Slide the switch into the lock position to secure the new battery.
Conclusione
UMass Dartmouth, Team 6-7, Martin Fall 2016 Membro di UMass Dartmouth, Team 6-7, Martin Fall 2016
UMASSD-MARTIN-F16S6G7
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 581
