Salta al contenuto principale
Dell Inspiron E1405 LCD Screen Replacement
Cosa ti serve
  1. Dell Inspiron E1405 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 LCD Screen Replacement: passo 2, immagine 1 di 3 Dell Inspiron E1405 LCD Screen Replacement: passo 2, immagine 2 di 3 Dell Inspiron E1405 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: passo 3, immagine 1 di 3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: passo 3, immagine 2 di 3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: passo 3, immagine 3 di 3
    • Use your fingers or a spudger to remove the six small rubber covers off the display assembly.
    • Remove the six 5.7 mm screws with a Phillips #00 screwdriver.
  4. Dell Inspiron E1405 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Use your fingers to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
    • Remove the front display bezel when it comes free.
  5. Dell Inspiron E1405 LCD Screen Replacement: passo 5, immagine 1 di 3 Dell Inspiron E1405 LCD Screen Replacement: passo 5, immagine 2 di 3 Dell Inspiron E1405 LCD Screen Replacement: passo 5, immagine 3 di 3
    • Remove the three 3.6 mm screws using a Phillips #00 screwdriver on both sides of the display.
    • Remove the LCD screen from the display assembly.
  6. Dell Inspiron E1405 LCD Screen Replacement: passo 6, immagine 1 di 2 Dell Inspiron E1405 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Unplug the VGA cable by pushing the two metal sides towards the middle of the strip.
    • Gently pull the VGA cable away to release the strip.
  7. Dell Inspiron E1405 LCD Screen Replacement: passo 7, immagine 1 di 2 Dell Inspiron E1405 LCD Screen Replacement: passo 7, immagine 2 di 2
    • Remove the next connection by pressing the two metal sides towards the middle. Then gently pull up the ribbon.
Conclusione
1Commento della guida
I need complete body *Dell INSPIRON E1405 .
St Master Fun - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 21
Tutti i Tempi: 600
