Salta al contenuto principale
Dell Inspiron E1405 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron E1405 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 Hard Drive Replacement: passo 2, immagine 1 di 3 Dell Inspiron E1405 Hard Drive Replacement: passo 2, immagine 2 di 3 Dell Inspiron E1405 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 2 Dell Inspiron E1405 Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 2
    • Locate the hard drive access door.
    • Remove the two 5.5mm screws with a #00 Phillips screwdriver. These screws are securing the hard drive access door.
  4. Dell Inspiron E1405 Hard Drive Replacement: passo 4, immagine 1 di 2 Dell Inspiron E1405 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Using your fingers, open and remove the access door from the laptop, exposing the hard drive underneath.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,164
