Salta al contenuto principale
Dell Inspiron B130 RAM and Wireless Replacement
Cosa ti serve
  1. Dell Inspiron B130 RAM and Wireless Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron B130 RAM and Wireless Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron B130 RAM and Wireless Replacement, Battery: passo 1, immagine 3 di 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 RAM and Wireless Replacement: passo 2, immagine 1 di 3 Dell Inspiron B130 RAM and Wireless Replacement: passo 2, immagine 2 di 3 Dell Inspiron B130 RAM and Wireless Replacement: passo 2, immagine 3 di 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 RAM and Wireless Replacement: passo 3, immagine 1 di 3 Dell Inspiron B130 RAM and Wireless Replacement: passo 3, immagine 2 di 3 Dell Inspiron B130 RAM and Wireless Replacement: passo 3, immagine 3 di 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: passo 4, immagine 1 di 2 Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: passo 4, immagine 2 di 2
    • Remove the three 6mm screws.
    • Lift the plastic cover off to reveal the RAM and the Wireless.
  5. Dell Inspiron B130 RAM and Wireless Replacement: passo 5, immagine 1 di 3 Dell Inspiron B130 RAM and Wireless Replacement: passo 5, immagine 2 di 3 Dell Inspiron B130 RAM and Wireless Replacement: passo 5, immagine 3 di 3
    • To remove the RAM, push outward against the metal brackets.
    • The first RAM will pop up so you can just pull it right out.
    • Repeat the first step again to remove the second RAM chip.
    • Installation is the reverse of removal.
  6. Dell Inspiron B130 RAM and Wireless Replacement: passo 6, immagine 1 di 2 Dell Inspiron B130 RAM and Wireless Replacement: passo 6, immagine 2 di 2
    • To remove the wireless chip, push outward on its two metal brackets.
    • Do not remove the chip just yet, the wire that connects this chip must first be removed.
  7. Dell Inspiron B130 RAM and Wireless Replacement: passo 7, immagine 1 di 2 Dell Inspiron B130 RAM and Wireless Replacement: passo 7, immagine 2 di 2
    • To remove the wire, hold the wireless chip firmly and pull the connection straight up off of the chip.
Conclusione
UMass Dartmouth, Team 1-8, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 279
