Salta al contenuto principale
Dell Inspiron B130 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron B130 Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron B130 Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron B130 Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 Hard Drive Replacement: passo 2, immagine 1 di 3 Dell Inspiron B130 Hard Drive Replacement: passo 2, immagine 2 di 3 Dell Inspiron B130 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 Hard Drive Replacement: passo 3, immagine 1 di 3 Dell Inspiron B130 Hard Drive Replacement: passo 3, immagine 2 di 3 Dell Inspiron B130 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 3 Dell Inspiron B130 Hard Drive Replacement, Hard Drive: passo 4, immagine 2 di 3 Dell Inspiron B130 Hard Drive Replacement, Hard Drive: passo 4, immagine 3 di 3
    • This particular computer is missing its hard drive.
    • Remove the two screws.
    • Remove the plastic cover by lifting from the groove as indicated.
    • Remove the hard drive from the computer by lifting up and out.
Conclusione
UMass Dartmouth, Team 1-8, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 635
