Salta al contenuto principale
Dell Inspiron 9300 WIFI Card Replacement
Cosa ti serve
  1. Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: passo 1, immagine 1 di 3 Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: passo 1, immagine 2 di 3 Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a size #0 Phillips screwdriver.
    • The screws do not come completely out.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
  2. Dell Inspiron 9300 WIFI Card Replacement: passo 2, immagine 1 di 2 Dell Inspiron 9300 WIFI Card Replacement: passo 2, immagine 2 di 2
    • Once the screws are loose, open the panel using a plastic opening tool to access the components below.
    • The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
  3. Dell Inspiron 9300 WIFI Card Replacement, WIFI Card: passo 3, immagine 1 di 2 Dell Inspiron 9300 WIFI Card Replacement, WIFI Card: passo 3, immagine 2 di 2
    • Gently pry up on the gold antennae connections using a spudger.
    • Gently pry open both retaining clips on either side of the WiFi card using a spudger.
    • Once the clips are open and the card is unplugged, it is safe to remove.
Conclusione
Master Techs Membro di Master Techs
Community
321 Membri
1.516 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 434
