Salta al contenuto principale
Dell Inspiron 9300 Speaker System Replacement
Cosa ti serve
  1. Dell Inspiron 9300 Speaker System Replacement, Prerequisite Only: passo 1, immagine 1 di 2 Dell Inspiron 9300 Speaker System Replacement, Prerequisite Only: passo 1, immagine 2 di 2
    • Remove the battery prior to working on any internal components.
    • Remove the twelve 6mm Phillips screws from the bottom of the case.
    • Remove the battery before working on internal components to ensure a safe working environment.
  2. Dell Inspiron 9300 Speaker System Replacement: passo 2, immagine 1 di 1
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  3. Dell Inspiron 9300 Speaker System Replacement: passo 3, immagine 1 di 3 Dell Inspiron 9300 Speaker System Replacement: passo 3, immagine 2 di 3 Dell Inspiron 9300 Speaker System Replacement: passo 3, immagine 3 di 3
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
  4. Dell Inspiron 9300 Speaker System Replacement: passo 4, immagine 1 di 2 Dell Inspiron 9300 Speaker System Replacement: passo 4, immagine 2 di 2
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  5. Dell Inspiron 9300 Speaker System Replacement: passo 5, immagine 1 di 2 Dell Inspiron 9300 Speaker System Replacement: passo 5, immagine 2 di 2
    • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger.
  6. Dell Inspiron 9300 Speaker System Replacement: passo 6, immagine 1 di 2 Dell Inspiron 9300 Speaker System Replacement: passo 6, immagine 2 di 2
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
    • Remove the trackpad ribbon cable from the motherboard using a spudger.
  7. Dell Inspiron 9300 Speaker System Replacement: passo 7, immagine 1 di 2 Dell Inspiron 9300 Speaker System Replacement: passo 7, immagine 2 di 2
    • Pull up and away on the track pad to expose the internal components below.
  8. Dell Inspiron 9300 Speaker System Replacement, Speaker System: passo 8, immagine 1 di 1
    • Remove the two 3mm Phillips screws holding the CD-ROM drive in place.
    • Slide the CD-ROM drive out of the lower case.
  9. Dell Inspiron 9300 Speaker System Replacement: passo 9, immagine 1 di 2 Dell Inspiron 9300 Speaker System Replacement: passo 9, immagine 2 di 2
    • Use a spudger to disconnect the subwoofer cable.
    • Repeat for the adjacent speaker connector.
  10. Dell Inspiron 9300 Speaker System Replacement: passo 10, immagine 1 di 1
    • Pry away the black tape that holds the sound system wires in place.
  11. Dell Inspiron 9300 Speaker System Replacement: passo 11, immagine 1 di 2 Dell Inspiron 9300 Speaker System Replacement: passo 11, immagine 2 di 2
    • Remove the 7mm Phillips screws that hold the subwoofer in place.
    • Remove the four (two for each speaker) 5mm Phillips screws that secure the left and right speakers.
Conclusione
USF Tampa, Team 16-6, Eyestone Fall 2016 Membro di USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 296
