Salta al contenuto principale
Dell Inspiron 9300 RAM Replacement
Cosa ti serve
  1. Dell Inspiron 9300 RAM Replacement, RAM: passo 1, immagine 1 di 2 Dell Inspiron 9300 RAM Replacement, RAM: passo 1, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a #0 Phillips screw driver.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
    • The screws are secured by retainer clips in the plastic panel and are not fully removable.
  2. Dell Inspiron 9300 RAM Replacement: passo 2, immagine 1 di 1
    • Remove the plastic panel.
  3. Dell Inspiron 9300 RAM Replacement: passo 3, immagine 1 di 2 Dell Inspiron 9300 RAM Replacement: passo 3, immagine 2 di 2
    Heavy-Duty Spudger
    Compra
    • Carefully pry away the retaining clips on either side of the ram modules using a spudger tool, until the card pops away from the motherboard.
    • Repeat for the second ram module if necessary.
  4. Dell Inspiron 9300 RAM Replacement: passo 4, immagine 1 di 1
    • Carefully pull the ram modules out of it's slot, away from the motherboard.
Conclusione
Master Techs Membro di Master Techs
Community
321 Membri
1.516 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 381
