Salta al contenuto principale
Dell Inspiron 9300 Modem Replacement
Cosa ti serve
  1. Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: passo 1, immagine 1 di 3 Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: passo 1, immagine 2 di 3 Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a size #0 Phillips screwdriver.
    • The screws do not come completely out.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
  2. Dell Inspiron 9300 Modem Replacement: passo 2, immagine 1 di 2 Dell Inspiron 9300 Modem Replacement: passo 2, immagine 2 di 2
    • Once the screws are loose, open the panel using a plastic opening tool to access the components below.
    • The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
  3. Dell Inspiron 9300 Modem Replacement, Modem Card: passo 3, immagine 1 di 2 Dell Inspiron 9300 Modem Replacement, Modem Card: passo 3, immagine 2 di 2
    • Remove the screw holding the card in place using a size #0 Phillips screwdriver.
    • Gently unplug the card from the connecting black wire using a black spudger.
    • The modem can now be safely removed.
Conclusione
Master Techs Membro di Master Techs
Community
321 Membri
1.516 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 200
