Salta al contenuto principale
Dell Inspiron 9300 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 9300 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Use the spudger to remove the top cover plate to expose the screws for the keyboard.
    • Be sure not to break the clips holding it in. Once the side has been lifted, gently lift the plate with your hand to remove it completely.
  2. Dell Inspiron 9300 Keyboard Replacement: passo 2, immagine 1 di 1
    • Remove the two 5mm Phillips screws holding the keyboard in place.
  3. Dell Inspiron 9300 Keyboard Replacement: passo 3, immagine 1 di 1
    • Pull the keyboard away from the laptop.
    • Be careful when pulling the keyboard not to damage the connecting ribbon underneath.
  4. Dell Inspiron 9300 Keyboard Replacement: passo 4, immagine 1 di 2 Dell Inspiron 9300 Keyboard Replacement: passo 4, immagine 2 di 2
    • Gently pull up on the blue tab to disconnect the keyboard.
    • Pull the keyboard up and away to safely remove the keyboard.
Conclusione
Ady Alhamra
Membro da: 09/26/16
149 Reputazione
1 Guida realizzata
USF Tampa, Team 16-6, Eyestone Fall 2016 Membro di USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 515
