Introduzione
This guide requires a Phillips #00 screwdriver
Parti
Nessuna parte richiesta.
  1. Unplug the laptop from the power adapter and turn the power off.
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Slide the battery-lock tab and hold.
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
    • Disconnect the antenna cables from the Mini-PCI card.
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
Conclusione
charlierefvem
Membro da: 11/01/2011
854 Reputazione
7 Guide realizzate
Cal Poly, Team 13-2, Forte Winter 2011 Membro di Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Membri
8 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,990
