Salta al contenuto principale
Dell Inspiron 9100 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 9100 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 9100 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 9100 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Keyboard Replacement: passo 2, immagine 1 di 3 Dell Inspiron 9100 Keyboard Replacement: passo 2, immagine 2 di 3 Dell Inspiron 9100 Keyboard Replacement: passo 2, immagine 3 di 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Turn the laptop around.
  4. Dell Inspiron 9100 Keyboard Replacement: passo 4, immagine 1 di 3 Dell Inspiron 9100 Keyboard Replacement: passo 4, immagine 2 di 3 Dell Inspiron 9100 Keyboard Replacement: passo 4, immagine 3 di 3
    • Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
    • Fold the screen back to 180 degrees.
    • Using your index fingers, pull up the hinge cover.
  5. Dell Inspiron 9100 Keyboard Replacement: passo 5, immagine 1 di 3 Dell Inspiron 9100 Keyboard Replacement: passo 5, immagine 2 di 3 Dell Inspiron 9100 Keyboard Replacement: passo 5, immagine 3 di 3
    • After the hinges pop, pull the hinge cover gently.
    • Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
  6. Dell Inspiron 9100 Keyboard Replacement: passo 6, immagine 1 di 1
    • Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
  7. Dell Inspiron 9100 Keyboard Replacement: passo 7, immagine 1 di 3 Dell Inspiron 9100 Keyboard Replacement: passo 7, immagine 2 di 3 Dell Inspiron 9100 Keyboard Replacement: passo 7, immagine 3 di 3
    • Tilt the keyboard away from the screen.
    • Pull up on the white tab underneath the keyboard to release the keyboard.
Conclusione
Ana
Membro da: 01/11/11
111 Reputazione
1 Guida realizzata
Cal Poly, Team 13-2, Forte Winter 2011 Membro di Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,976
