Salta al contenuto principale
Dell Inspiron 910 RAM Replacement
Cosa ti serve
  1. Dell Inspiron 910 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 RAM Replacement, Preparation: passo 2, immagine 1 di 1
    • Remember to power off the device before starting!
    • Disconnect any cables or external devices from the laptop, then flip it and remove the battery by pressing the battery tabs inward.
  3. Dell Inspiron 910 RAM Replacement: passo 3, immagine 1 di 1
    • Locate the large black panel with two screws holding it in place. (This is the panel with ventilation holes)
    • Unscrew both of the screws using a Philips Screwdriver.
  4. Dell Inspiron 910 RAM Replacement: passo 4, immagine 1 di 1
    • Remove the panel by pulling upward.
    • Removal may require some force!
  5. Dell Inspiron 910 RAM Replacement: passo 5, immagine 1 di 2 Dell Inspiron 910 RAM Replacement: passo 5, immagine 2 di 2
    • After removing the panel, locate the memory modules.
    • Look for the silver tabs on either side of the white plastic holding the RAM in place. Then gently remove the RAM.
  6. Dell Inspiron 910 RAM Replacement, For Reinstallation: passo 6, immagine 1 di 1
    • Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
    • Congratulations! You have completed the guide.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 14-10, Forte Spring 2012 Membro di Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,877
