Salta al contenuto principale
Dell Inspiron 910 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 910 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Keyboard Replacement, Keyboard: passo 2, immagine 1 di 1
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Keyboard Replacement: passo 3, immagine 1 di 1
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 14-10, Forte Spring 2012 Membro di Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Membri
7 Guide realizzate
Un commento
Impossible if you don’t have this tutorial.
2 Photos!
Perfect!
WildBill - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,838
