Salta al contenuto principale
Dell Inspiron 8600 Upper Case Replacement
Cosa ti serve
  1. Dell Inspiron 8600 Upper Case Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: passo 2, immagine 1 di 3 Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: passo 2, immagine 2 di 3 Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: passo 2, immagine 3 di 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Upper Case Replacement: passo 3, immagine 1 di 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Upper Case Replacement, Keyboard: passo 4, immagine 1 di 3 Dell Inspiron 8600 Upper Case Replacement, Keyboard: passo 4, immagine 2 di 3 Dell Inspiron 8600 Upper Case Replacement, Keyboard: passo 4, immagine 3 di 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Upper Case Replacement, Display Module: passo 5, immagine 1 di 2 Dell Inspiron 8600 Upper Case Replacement, Display Module: passo 5, immagine 2 di 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. Dell Inspiron 8600 Upper Case Replacement: passo 6, immagine 1 di 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Dell Inspiron 8600 Upper Case Replacement: passo 7, immagine 1 di 2 Dell Inspiron 8600 Upper Case Replacement: passo 7, immagine 2 di 2
    • Lift the display module directly upwards from the base of the computer.
  8. Dell Inspiron 8600 Upper Case Replacement: passo 8, immagine 1 di 1
    • Now remove the display module.
  9. Dell Inspiron 8600 Upper Case Replacement, Upper Case: passo 9, immagine 1 di 2 Dell Inspiron 8600 Upper Case Replacement, Upper Case: passo 9, immagine 2 di 2
    • Remove the two screws that hold the upper case.
    • You can now pop up the upper case and replace.
Conclusione
John Nesthus
Membro da: 04/13/11
186 Reputazione
6 Guide realizzate
Cal Poly, Team 18-22, Garner Spring 2011 Membro di Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,570
