Salta al contenuto principale
Dell Inspiron 8600 Power Button Replacement
Cosa ti serve
  1. Dell Inspiron 8600 Power Button Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Power Button Replacement, Power Button: passo 2, immagine 1 di 3 Dell Inspiron 8600 Power Button Replacement, Power Button: passo 2, immagine 2 di 3 Dell Inspiron 8600 Power Button Replacement, Power Button: passo 2, immagine 3 di 3
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Power Button Replacement: passo 3, immagine 1 di 1
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
Conclusione
Altre 3 persone hanno completato questa guida.
Brian Murphy
Membro da: 04/13/11
368 Reputazione
4 Guide realizzate
Cal Poly, Team 18-22, Garner Spring 2011 Membro di Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,134
