Salta al contenuto principale
Dell Inspiron 8600 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 8600 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: passo 2, immagine 1 di 3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: passo 2, immagine 2 di 3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: passo 2, immagine 3 di 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Keyboard Replacement: passo 3, immagine 1 di 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: passo 4, immagine 2 di 3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: passo 4, immagine 3 di 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
Conclusione
Altre 2 persone hanno completato questa guida.
Perry
Membro da: 04/12/11
251 Reputazione
4 Guide realizzate
Cal Poly, Team 18-22, Garner Spring 2011 Membro di Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Membri
16 Guide realizzate
Un commento
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,891
