Salta al contenuto principale
Dell Inspiron 8600 Hinge Cover Replacement
Cosa ti serve
  1. Dell Inspiron 8600 Hinge Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Hinge Cover Replacement, Hinge Cover: passo 2, immagine 1 di 3 Dell Inspiron 8600 Hinge Cover Replacement, Hinge Cover: passo 2, immagine 2 di 3 Dell Inspiron 8600 Hinge Cover Replacement, Hinge Cover: passo 2, immagine 3 di 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Hinge Cover Replacement: passo 3, immagine 1 di 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
Conclusione
John Nesthus
Membro da: 04/13/11
186 Reputazione
6 Guide realizzate
Cal Poly, Team 18-22, Garner Spring 2011 Membro di Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,537
