Salta al contenuto principale
Dell Inspiron 8600 Display Removal
Cosa ti serve
  1. Dell Inspiron 8600 Display Removal, Battery: passo 1, immagine 1 di 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Display Removal, Hinge Cover: passo 2, immagine 1 di 3 Dell Inspiron 8600 Display Removal, Hinge Cover: passo 2, immagine 2 di 3 Dell Inspiron 8600 Display Removal, Hinge Cover: passo 2, immagine 3 di 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Display Removal: passo 3, immagine 1 di 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Display Removal, Display Module: passo 4, immagine 1 di 2 Dell Inspiron 8600 Display Removal, Display Module: passo 4, immagine 2 di 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Display Removal: passo 5, immagine 1 di 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Display Removal: passo 6, immagine 1 di 2 Dell Inspiron 8600 Display Removal: passo 6, immagine 2 di 2
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Display Removal: passo 7, immagine 1 di 1
    • Now remove the display module.
Conclusione
Altre 2 persone hanno completato questa guida.
Victor
Membro da: 04/06/11
187 Reputazione
1 Guida realizzata
Cal Poly, Team 18-22, Garner Spring 2011 Membro di Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,877
