Introduzione
Does your battery life seem to be diminishing? Are you constantly in search of a power outlet in public spaces? It may be time to replace the battery in your device; this guide will reduce your charging time and double your screen time! Inside the device lies a 68 Wh Standard Rechargeable Dell Li-ion Battery. The following guide will illustrate the steps to replace this vital component.
Cosa ti serve
Use a Phillips #000 screwdriver to remove seven screws securing the base face of your device.
Unscrew the remaining two screws in the corners closest to the bottom of the base of the laptop.
Altre 2 persone hanno completato questa guida.
