Salta al contenuto principale
Dell Inspiron 7586 2-in-1 SSD Replacement
Cosa ti serve
  1. Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: passo 1, immagine 1 di 3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: passo 1, immagine 2 di 3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: passo 1, immagine 3 di 3
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #00 screwdriver to remove nine screws from the back case.
    • Insert an opening tool or spudger in the seam between the back case and the body of the laptop.
    • Work your way around the perimeter of the laptop and release the clips that secure the back case.
    • You will hear a clicking sound as the the clips are released and the back case is being removed.
    • Remove the back case.
  2. Dell Inspiron 7586 2-in-1 SSD Replacement: passo 2, immagine 1 di 3 Dell Inspiron 7586 2-in-1 SSD Replacement: passo 2, immagine 2 di 3 Dell Inspiron 7586 2-in-1 SSD Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the single screw securing the NVME drive.
    • Once the screw is removed, the SSD should pop up.
  3. Dell Inspiron 7586 2-in-1 SSD Replacement: passo 3, immagine 1 di 3 Dell Inspiron 7586 2-in-1 SSD Replacement: passo 3, immagine 2 di 3 Dell Inspiron 7586 2-in-1 SSD Replacement: passo 3, immagine 3 di 3
    • Gently slide the SSD out of the slot.
    • Make sure to gently pull out the drive to avoid damaging the M.2 slot where you insert the new SSD.
  4. Dell Inspiron 7586 2-in-1 SSD Replacement: passo 4, immagine 1 di 2 Dell Inspiron 7586 2-in-1 SSD Replacement: passo 4, immagine 2 di 2
    • Align the tooth edge of the SSD with the indents on the drive socket and gently insert the replacement SSD.
    • Press down on the SSD so the screw hole and drive align.
    • Use a Phillips #00 screwdriver to replace the screw.
    • Don't be scared to push down on the SSD as it should be level with the rest of the components.
Conclusione
Altre 2 persone hanno completato questa guida.
Mike03
Membro da: 03/05/24
139 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 70
