Salta al contenuto principale
Dell Inspiron 7568 Keyboard Replacement Guide
Cosa ti serve
  1. Dell Inspiron 7568 Keyboard Replacement Guide, Battery: passo 1, immagine 1 di 2 Dell Inspiron 7568 Keyboard Replacement Guide, Battery: passo 1, immagine 2 di 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Keyboard Replacement Guide: passo 2, immagine 1 di 2 Dell Inspiron 7568 Keyboard Replacement Guide: passo 2, immagine 2 di 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Keyboard Replacement Guide, Display Assembly: passo 3, immagine 1 di 2 Dell Inspiron 7568 Keyboard Replacement Guide, Display Assembly: passo 3, immagine 2 di 2
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
    • Doing this will allow one to access the LCD-motherboard connector cables.
  4. Dell Inspiron 7568 Keyboard Replacement Guide: passo 4, immagine 1 di 2 Dell Inspiron 7568 Keyboard Replacement Guide: passo 4, immagine 2 di 2
    • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
  5. Dell Inspiron 7568 Keyboard Replacement Guide: passo 5, immagine 1 di 3 Dell Inspiron 7568 Keyboard Replacement Guide: passo 5, immagine 2 di 3 Dell Inspiron 7568 Keyboard Replacement Guide: passo 5, immagine 3 di 3
    • Disconnect the antenna cable (under the left hinge)
    • Disconnect the LCD and Touchscreen display cables under the right hinge.
    • These are a set of two cables. For better image see image two in step one of this guide.
  6. Dell Inspiron 7568 Keyboard Replacement Guide: passo 6, immagine 1 di 1
    • Carefully separate the screen from the bottom half of the device.
  7. Dell Inspiron 7568 Keyboard Replacement Guide, Cooling Fan: passo 7, immagine 1 di 2 Dell Inspiron 7568 Keyboard Replacement Guide, Cooling Fan: passo 7, immagine 2 di 2
    • Begin by unclipping the cable connecting the fan and the motherboard.
    • Gently separate the motherboard cable from the clamp at the bottom of the fan.
    • Remove the cable.
  8. Dell Inspiron 7568 Keyboard Replacement Guide: passo 8, immagine 1 di 2 Dell Inspiron 7568 Keyboard Replacement Guide: passo 8, immagine 2 di 2
    • Remove the two 3mm Phillips #1 screws that hold the fan into place.
    • Remove the fan.
  9. Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: passo 9, immagine 1 di 3 Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: passo 9, immagine 2 di 3 Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: passo 9, immagine 3 di 3
    • Once the battery, screen, cooling fan, trackpad are out, the device would resemble the one in the first picture of this step.
    • Unscrew the three screws connecting the copper pipe to the motherboard.
    • Remove the copper pipe.
  10. Dell Inspiron 7568 Keyboard Replacement Guide: passo 10, immagine 1 di 3 Dell Inspiron 7568 Keyboard Replacement Guide: passo 10, immagine 2 di 3 Dell Inspiron 7568 Keyboard Replacement Guide: passo 10, immagine 3 di 3
    • Unscrew the three 2mm wafer screws holding the motherboard.
    • Unplug the DC cable from the motherboard.
  11. Dell Inspiron 7568 Keyboard Replacement Guide: passo 11, immagine 1 di 2 Dell Inspiron 7568 Keyboard Replacement Guide: passo 11, immagine 2 di 2
    • Unplug the connecting strip
  12. Dell Inspiron 7568 Keyboard Replacement Guide: passo 12, immagine 1 di 3 Dell Inspiron 7568 Keyboard Replacement Guide: passo 12, immagine 2 di 3 Dell Inspiron 7568 Keyboard Replacement Guide: passo 12, immagine 3 di 3
    • Unplug the hard-drive cable
    • Remove the motherboard
  13. Dell Inspiron 7568 Keyboard Replacement Guide: passo 13, immagine 1 di 2 Dell Inspiron 7568 Keyboard Replacement Guide: passo 13, immagine 2 di 2
    • Unscrew the three 3mm screws holding the hard drive (using a ph1 screwdriver bit)
    • Remove the hard drive
  14. Dell Inspiron 7568 Keyboard Replacement Guide: passo 14, immagine 1 di 2 Dell Inspiron 7568 Keyboard Replacement Guide: passo 14, immagine 2 di 2
    • Unscrew the two 3mm screws holding the daughter board (using the ph1 screwdriver bit).
    • Set the daughterboard aside. NOTE: the daughter board doesn't have to be removed
  15. Dell Inspiron 7568 Keyboard Replacement Guide: passo 15, immagine 1 di 2 Dell Inspiron 7568 Keyboard Replacement Guide: passo 15, immagine 2 di 2
    • Unscrew & remove the twenty-eight 2mm bracket screws holding the keyboard bracket (using a PH000 screwdriver bit)
    • Remove the keyboard bracket
  16. Dell Inspiron 7568 Keyboard Replacement Guide: passo 16, immagine 1 di 1
    • Unscrew & remove the sixteen 2mm screws holding the keyboard (using a PH000 screwdriver bit)
  17. Dell Inspiron 7568 Keyboard Replacement Guide: passo 17, immagine 1 di 3 Dell Inspiron 7568 Keyboard Replacement Guide: passo 17, immagine 2 di 3 Dell Inspiron 7568 Keyboard Replacement Guide: passo 17, immagine 3 di 3
    • Unplug the keyboard ("KB") and backlight ("BL") cable
    • Remove the keyboard.
Conclusione
Luis Velez
Membro da: 02/19/17
440 Reputazione
2 Guide realizzate
USF Tampa, Team S2-G2, Lacy Spring 2017 Membro di USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,077
