Salta al contenuto principale
Dell Inspiron 7568 Hard-Drive Replacement
Cosa ti serve
  1. Dell Inspiron 7568 Hard-Drive Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 7568 Hard-Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Hard-Drive Replacement: passo 2, immagine 1 di 2 Dell Inspiron 7568 Hard-Drive Replacement: passo 2, immagine 2 di 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Hard-Drive Replacement, Hard-Drive: passo 3, immagine 1 di 1
    • Remove the three 3mm Phillips #1 screws connecting the hard drive to the laptop.
  4. Dell Inspiron 7568 Hard-Drive Replacement: passo 4, immagine 1 di 2 Dell Inspiron 7568 Hard-Drive Replacement: passo 4, immagine 2 di 2
    • Disconnect the highlighted SATA cable from the hard drive.
  5. Dell Inspiron 7568 Hard-Drive Replacement: passo 5, immagine 1 di 1
    • Remove the four 3mm Phillips #1 screws of the hard drive. Both sides look identical.
  6. Dell Inspiron 7568 Hard-Drive Replacement: passo 6, immagine 1 di 1
    • Remove the hard drive (right) from its frame (left).
Conclusione
Elijah Basile
Membro da: 11/06/19
358 Reputazione
4 Guide realizzate
IUPUI, Team S1-G4, Stella Fall 2019 Membro di IUPUI, Team S1-G4, Stella Fall 2019
IUPUI-STELLA-F19S1G4
4 Membri
4 Guide realizzate
Un commento
Will a 9mm 2.5” SSD fit in these? or can it be forced in? p16 of the spec sheet says “7mm” but I’m not sure if that’s just saying stock configuration just comes with a 7mm drive? or that it only supports up to 7mm?: https://dl.dell.com/manuals/all-products... Any clarification appreciated, thanks!
Blacknova - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 369
