Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
By following the steps in this guide one should be able to replace the fan of a Dell Inspiron 7568 in under six minutes. The only tool necessary for this project is a Phillips #1 screwdriver.
Parti
Nessuna parte specificata.
  1. Remove the ten 7mm Phillips #1 screws on the bottom cover. Remove the bottom cover.
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Remove the four 3mm Phillips #1 screws holding the battery. Unhinge the connector cable to the battery.
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Begin by unclipping the cable connecting the fan and the motherboard. Gently separate  the motherboard cable from the clamp at the bottom of the fan.
    • Begin by unclipping the cable connecting the fan and the motherboard.
    • Gently separate the motherboard cable from the clamp at the bottom of the fan.
    • Remove the cable.
  5. Remove the two 3mm Phillips #1 screws that hold the fan into place. Remove the fan.
    • Remove the two 3mm Phillips #1 screws that hold the fan into place.
    • Remove the fan.
Conclusione
Altre 3 persone hanno completato questa guida.
Yash Samant
Membro da: 22/02/2017
373 Reputazione
3 Guide realizzate
USF Tampa, Team S2-G2, Lacy Spring 2017 Membro di USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 432
