Salta al contenuto principale
Dell Inspiron 6400 keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: passo 1, immagine 1 di 3 Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: passo 1, immagine 2 di 3 Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: passo 1, immagine 3 di 3
    • Turn over laptop .Remove battery from laptop by pushing the two tabs are highlighted in blue. Place the battery off to the side.
  2. Dell Inspiron 6400 keyboard Replacement: passo 2, immagine 1 di 3 Dell Inspiron 6400 keyboard Replacement: passo 2, immagine 2 di 3 Dell Inspiron 6400 keyboard Replacement: passo 2, immagine 3 di 3
    • Remove the 3 screws highlighted in red that secure the keyboard to the case using the screwdriver with largest phillips head in the box. Make
  3. Dell Inspiron 6400 keyboard Replacement: passo 3, immagine 1 di 3 Dell Inspiron 6400 keyboard Replacement: passo 3, immagine 2 di 3 Dell Inspiron 6400 keyboard Replacement: passo 3, immagine 3 di 3
    • Turn the device right side up and open the device to view the keyboard.
    • Remove the keyboard away from the case ,using a plastic spudger if necessary.
    • The keyboard will still be attached to the motherboard by a ribbon cable.
  4. Dell Inspiron 6400 keyboard Replacement: passo 4, immagine 1 di 3 Dell Inspiron 6400 keyboard Replacement: passo 4, immagine 2 di 3 Dell Inspiron 6400 keyboard Replacement: passo 4, immagine 3 di 3
    • Replace the new keyboard with plastic spudger.
    • The keyboard will have to be attached to the motherboard by a ribbon cable.
    • Snapped the keyboard back in place.
  5. Dell Inspiron 6400 keyboard Replacement: passo 5, immagine 1 di 3 Dell Inspiron 6400 keyboard Replacement: passo 5, immagine 2 di 3 Dell Inspiron 6400 keyboard Replacement: passo 5, immagine 3 di 3
    • Flip over the laptop
    • Put the screws back in laptop
  6. Dell Inspiron 6400 keyboard Replacement: passo 6, immagine 1 di 2 Dell Inspiron 6400 keyboard Replacement: passo 6, immagine 2 di 2
    • Place the battery and lock it into place
Conclusione
kempc8
Membro da: 11/22/13
905 Reputazione
7 Guide realizzate
K and K Fixit Membro di K and K Fixit
Business
1 Membro
11 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,068
