Salta al contenuto principale
Dell Inspiron 600m LCD Replacement
Cosa ti serve
  1. Dell Inspiron 600m LCD Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 600m LCD Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 600m LCD Replacement, Battery: passo 1, immagine 3 di 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m LCD Replacement, LCD: passo 2, immagine 1 di 2 Dell Inspiron 600m LCD Replacement, LCD: passo 2, immagine 2 di 2
    • Using fingernails or a spudger, push any direction on the rubber dots to remove them from the plastic cover.
    • Underneath each rubber dot will be a screw. Remove these screws with the Phillips #00 screwdriver.
  3. Dell Inspiron 600m LCD Replacement: passo 3, immagine 1 di 2 Dell Inspiron 600m LCD Replacement: passo 3, immagine 2 di 2
    • Use the IFixit Opening Tool to un-clip the plastic cover, detaching it from the rest of the screen.
    • There are clips about every inch around the right, left, and top of the plastic cover. Be sure that all of them are unclipped.
  4. Dell Inspiron 600m LCD Replacement: passo 4, immagine 1 di 1
    • Pull straight up on the cover to lift the cover off of the rest of the screen.
    • The bottom part of the plastic is a little sticky.
  5. Dell Inspiron 600m LCD Replacement: passo 5, immagine 1 di 1
    • Remove four screws (two on each side of the screen) with the Phillips #00 screwdriver.
    • The middle screw does not need to be removed.
  6. Dell Inspiron 600m LCD Replacement: passo 6, immagine 1 di 1
    • Gently lift the LCD panel off of the base.
    • The LCD is still attached to the computer. Do not pull too hard or you could break the cable.
  7. Dell Inspiron 600m LCD Replacement: passo 7, immagine 1 di 3 Dell Inspiron 600m LCD Replacement: passo 7, immagine 2 di 3 Dell Inspiron 600m LCD Replacement: passo 7, immagine 3 di 3
    • Flip the LCD panel over.
    • Do not touch on or near the back of the panel where it says "Don't Touch." LCD panels contain mercury which is hazardous to humans.
    • Remove the cable by squeezing each side of the connector and gently pulling straight out.
  8. Dell Inspiron 600m LCD Replacement: passo 8, immagine 1 di 3 Dell Inspiron 600m LCD Replacement: passo 8, immagine 2 di 3 Dell Inspiron 600m LCD Replacement: passo 8, immagine 3 di 3
    • Remove the cable at the base of the laptop by pulling up on the yellow tab attached to the cable.
Conclusione
Altre 4 persone hanno completato questa guida.
Alex Klimaj
Membro da: 04/01/11
143 Reputazione
1 Guida realizzata
Cal Poly, Team 10-40, Forte Spring 2011 Membro di Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 6,865
