Salta al contenuto principale
Dell Inspiron 600m Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 600m Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 600m Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 600m Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 1
    • The hard drive is located here.
  3. Dell Inspiron 600m Hard Drive Replacement: passo 3, immagine 1 di 1
    • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  4. Dell Inspiron 600m Hard Drive Replacement: passo 4, immagine 1 di 1
    • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
Conclusione
Altre 7 persone hanno completato questa guida.
Todd
Membro da: 04/05/11
146 Reputazione
1 Guida realizzata
Cal Poly, Team 10-40, Forte Spring 2011 Membro di Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Membri
8 Guide realizzate
2 Commenti
What size is the hard drive, you know, to buy a new one?
Ethan White - Replica
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 44
Tutti i Tempi: 17,323
