Salta al contenuto principale
Dell Inspiron 6000 Keyboard Replacement
Cosa ti serve
  1. Dell Inspiron 6000 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Keyboard Replacement: passo 2, immagine 1 di 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: passo 3, immagine 3 di 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Keyboard Replacement: passo 4, immagine 1 di 2 Dell Inspiron 6000 Keyboard Replacement: passo 4, immagine 2 di 2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Keyboard Replacement: passo 5, immagine 1 di 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Keyboard Replacement: passo 6, immagine 1 di 3 Dell Inspiron 6000 Keyboard Replacement: passo 6, immagine 2 di 3 Dell Inspiron 6000 Keyboard Replacement: passo 6, immagine 3 di 3
    • Gently pull the blue tab up until it comes away from computer.
Conclusione
Altre 5 persone hanno completato questa guida.
Jacob DeWar
Membro da: 09/23/14
533 Reputazione
3 Guide realizzate
USF Tampa, Team 11-1, Blackwell Fall 2014 Membro di USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Membri
7 Guide realizzate
Un commento
Hi there, my dell inspiron 6000 does not power up when I switch on. This happened after I remove my keypad to clean.. Any idea why?
John KAPA - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,095
