Salta al contenuto principale
Dell Inspiron 6000 Fan Replacement
Cosa ti serve
  1. Dell Inspiron 6000 Fan Replacement, Battery: passo 1, immagine 1 di 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Fan Replacement: passo 2, immagine 1 di 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Fan Replacement, Keyboard: passo 3, immagine 1 di 3 Dell Inspiron 6000 Fan Replacement, Keyboard: passo 3, immagine 2 di 3 Dell Inspiron 6000 Fan Replacement, Keyboard: passo 3, immagine 3 di 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Fan Replacement: passo 4, immagine 1 di 2 Dell Inspiron 6000 Fan Replacement: passo 4, immagine 2 di 2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Fan Replacement: passo 5, immagine 1 di 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Fan Replacement: passo 6, immagine 1 di 3 Dell Inspiron 6000 Fan Replacement: passo 6, immagine 2 di 3 Dell Inspiron 6000 Fan Replacement: passo 6, immagine 3 di 3
    • Gently pull the blue tab up until it comes away from computer.
  7. Dell Inspiron 6000 Fan Replacement, Fan: passo 7, immagine 1 di 1
    • Unscrew the 4 mm Phillips #00 screw.
    • The screw will remain attached to the cord when fully removed.
  8. Dell Inspiron 6000 Fan Replacement: passo 8, immagine 1 di 2 Dell Inspiron 6000 Fan Replacement: passo 8, immagine 2 di 2
    • Gently pull the blue tab to separate the screen connection from the laptop.
    • Gently pull and disconnect the white and black cords from the power source.
  9. Dell Inspiron 6000 Fan Replacement: passo 9, immagine 1 di 2 Dell Inspiron 6000 Fan Replacement: passo 9, immagine 2 di 2
    • Remove four 4mm #00 Philips screws from the screen hinges.
    • Lift the screen away from the laptop.
  10. Dell Inspiron 6000 Fan Replacement: passo 10, immagine 1 di 2 Dell Inspiron 6000 Fan Replacement: passo 10, immagine 2 di 2
    • Remove two 4 mm Philips #00 screws that connect top of laptop to base..
  11. Dell Inspiron 6000 Fan Replacement: passo 11, immagine 1 di 1
    • Flip laptop the over and remove thirteen 6mm Philips #00 screws.
  12. Dell Inspiron 6000 Fan Replacement: passo 12, immagine 1 di 2 Dell Inspiron 6000 Fan Replacement: passo 12, immagine 2 di 2
    • Insert the plastic opening tool in between the back and front plates of the laptop
  13. Dell Inspiron 6000 Fan Replacement: passo 13, immagine 1 di 1
  14. Dell Inspiron 6000 Fan Replacement: passo 14, immagine 1 di 1
    • Remove the fan power cord
  15. Dell Inspiron 6000 Fan Replacement: passo 15, immagine 1 di 2 Dell Inspiron 6000 Fan Replacement: passo 15, immagine 2 di 2
    • Using your hand, lift the fan from the laptop.
Conclusione
Altre 5 persone hanno completato questa guida.
Jacob DeWar
Membro da: 09/23/14
533 Reputazione
3 Guide realizzate
USF Tampa, Team 11-1, Blackwell Fall 2014 Membro di USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,313
