Salta al contenuto principale
Dell Inspiron 5570 Battery Disconnect
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Dell Inspiron 5570 Battery Disconnect, Unfasten the back cover: passo 1, immagine 1 di 2 Dell Inspiron 5570 Battery Disconnect, Unfasten the back cover: passo 1, immagine 2 di 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips screwdriver to remove the seven screws securing the back cover:
    • Three 5 mm-long screws
    • Four 7.5 mm-long screws
    • Loosen the three captive screws.
  2. Dell Inspiron 5570 Battery Disconnect, Unclip the front corners: passo 2, immagine 1 di 2 Dell Inspiron 5570 Battery Disconnect, Unclip the front corners: passo 2, immagine 2 di 2
    • Flip the laptop upright and open the lid so that the keyboard is exposed.
    • Insert an opening pick between the front right corner of the back cover and the chassis.
    • Pry upward to release the retaining clips holding the cover.
    • You'll hear clicks whenever a clip is released.
    • Repeat this procedure for the opposite corner.
  3. Dell Inspiron 5570 Battery Disconnect, Unclip the front edge: passo 3, immagine 1 di 2 Dell Inspiron 5570 Battery Disconnect, Unclip the front edge: passo 3, immagine 2 di 2
    • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
    • Pry upward to release the clips along the front edge of the laptop.
  4. Dell Inspiron 5570 Battery Disconnect, Remove the back cover: passo 4, immagine 1 di 3 Dell Inspiron 5570 Battery Disconnect, Remove the back cover: passo 4, immagine 2 di 3 Dell Inspiron 5570 Battery Disconnect, Remove the back cover: passo 4, immagine 3 di 3
    • Close the screen to the laptop and flip it over.
    • Pull the left side of the back cover away from the frame and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. Dell Inspiron 5570 Battery Disconnect, Disconnect the battery: passo 5, immagine 1 di 2 Dell Inspiron 5570 Battery Disconnect, Disconnect the battery: passo 5, immagine 2 di 2
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
Conclusione
Clay Eickemeyer
Membro da: 09/19/22
82.264 Reputazione
455 Guide realizzate
Guide Team Membro di Guide Team
Staff
9 Membri
11.491 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 21
