Salta al contenuto principale
Dell Inspiron 5379 Hard Drive Replacement
Cosa ti serve
  1. Dell Inspiron 5379 Hard Drive Replacement, Peeling the Tape: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Peel off the tape that secures the hard-drive cable to the palm-rest assembly.
  2. Dell Inspiron 5379 Hard Drive Replacement, Disconnecting the Hard Drive Cable: passo 2, immagine 1 di 1
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 5379 Hard Drive Replacement, Remove the Screws: passo 3, immagine 1 di 1
    • Remove the two screws (M2x3.5) that secure the hard-drive assembly to the palm-rest assembly.
  4. Dell Inspiron 5379 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 4, immagine 1 di 1
    • Lift the hard-drive assembly, along with its cable, off the palm-rest assembly.
  5. Dell Inspiron 5379 Hard Drive Replacement, Disconnecting the Interposer: passo 5, immagine 1 di 1
    • Disconnect the interposer from the hard-drive assembly.
  6. Dell Inspiron 5379 Hard Drive Replacement, Remove the Screws: passo 6, immagine 1 di 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 5379 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 7, immagine 1 di 2 Dell Inspiron 5379 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 7, immagine 2 di 2
    • Lift the hard-drive bracket off the hard drive.
  8. Dell Inspiron 5379 Hard Drive Replacement, Align the Screw Holes: passo 8, immagine 1 di 1
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 5379 Hard Drive Replacement, Replace the Screws: passo 9, immagine 1 di 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 5379 Hard Drive Replacement, Connecting the Interposer: passo 10, immagine 1 di 1
    • Connect the interposer to the hard-drive assembly.
  11. Dell Inspiron 5379 Hard Drive Replacement, Align the Screw Holes: passo 11, immagine 1 di 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
  12. Dell Inspiron 5379 Hard Drive Replacement, Replace the Screws: passo 12, immagine 1 di 1
    • Replace the two screws (M2x3.5) that secure the hard-drive assembly to the palm-rest assembly.
  13. Dell Inspiron 5379 Hard Drive Replacement, Connecting the Hard-Drive Cable: passo 13, immagine 1 di 1
    • Connect the hard-drive cable to the system board.
  14. Dell Inspiron 5379 Hard Drive Replacement, Adhering the Tape: passo 14, immagine 1 di 1
    • Adhere the tape that secures the hard-drive cable to the palm-rest assembly.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,089
