Salta al contenuto principale
Dell Inspiron 5379 Display Assembly Replacement
Cosa ti serve
  1. Dell Inspiron 5379 Display Assembly Replacement, Peeling the Tape: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Peel the tape that secures the display cable and touch-screen board-cable to the system board.
  2. Dell Inspiron 5379 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, immagine 1 di 1
    • Open the latches to disconnect the display cable and the touch-screen board-cable from the system board.
  3. Dell Inspiron 5379 Display Assembly Replacement, Open the Display Cable: passo 3, immagine 1 di 1
    • Turn the computer over and open the display as far as possible.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  4. Dell Inspiron 5379 Display Assembly Replacement, Remove the Screws: passo 4, immagine 1 di 1
    • Place the computer face down on a flat surface.
    • Remove the four screws (M2.5x2.5) that secure the display assembly to the palm-rest assembly.
  5. Dell Inspiron 5379 Display Assembly Replacement, Lifting the Display Assembly: passo 5, immagine 1 di 1
    • Lift the display assembly off the palm-rest assembly.
  6. Dell Inspiron 5379 Display Assembly Replacement, Placing the Display Assembly: passo 6, immagine 1 di 2 Dell Inspiron 5379 Display Assembly Replacement, Placing the Display Assembly: passo 6, immagine 2 di 2
    • Place the NEW display assembly face down on the palm-rest assembly.
  7. Dell Inspiron 5379 Display Assembly Replacement, Align the Screw Holes: passo 7, immagine 1 di 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  8. Dell Inspiron 5379 Display Assembly Replacement, Replace the Screws: passo 8, immagine 1 di 1
    • Replace the four screws (M2.5x2.5) that secure the display assembly to the palm-rest assembly.
  9. Dell Inspiron 5379 Display Assembly Replacement, Sliding the Display Cable: passo 9, immagine 1 di 1
    • Close the display and turn the computer over.
    • Slide the display cable and the touch-screen board-cable into their respective connectors on the system board and close the latches to secure the cables.
  10. Dell Inspiron 5379 Display Assembly Replacement, Adhering the Tape: passo 10, immagine 1 di 1
    • Adhere the pieces of tape that secure the display cable and the touch-screen board-cable to their respective connectors on the system board.
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.243 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
42 Membri
1.989 Guide realizzate
4 Commenti
Very nice post! That's a great website I have visited, thank you for your essentials words hotmail sign in
Martin Tolley - Replica
Perkembangan Teknologi Memang Tidak Ada Habisnya Setiap Tahun nya Selalu di Hadirkan Teknologi Terbaru Baik itu Dari Smartphone Ataupun Laptop. Website Kami Hadir Sebagai Portal Teknologi Informasi Indonesia Membahas seputar Tutorial Android, Review Gadget, Review Laptop, Aplikasi serta Tutorial Mengenai Teknologi
Blast King - Replica
Not a useful post. Caused more trouble than help. Disconnect the battery, unsnap the old screen from case, pull off camera section, unscrew one flat looking screw, disconnect one wire, put in new screen, put camera stuff back in, screw in the one part you unscrewed, connect the one wire, snap on case, connect battery, done. All this post did was confuse me and make me take way longer.
Ben Sawyer - Replica
Situs Nonton Anime Sub Indo terbaru terupdate dan terlengkap serta kalian juga nonton film series di layarkaca21 atau nonton dan streaming series terbaru Dunia21 kalian juga bisa Baca Manhwa Bahasa indonesia terbaru dan terupdate and if you want you can Read Manhwa Online with english translation sambil nonton film di IDLIX.
layar kaca - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,146
