Introduzione
You will be able to access wires connecting your screen and replace it if needed.
Parti
Nessuna parte richiesta.
  1. Remove battery
    • Remove battery
    • Open screen so that it lies flat.
  2. Starting from the right side of the hinge cover,  use the flat end of the spudger to pry up the hinge cover and gently remove it.
    • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
    • Remove the four M2 x 3-mm screws holding in the keyboard.
    • Lift keyboard and detach the interface connector.
    • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile, easily dislocate and would be time-consuming to replace.
    • Remove two screws (5.8mm) located at the rear of the laptop.
    • Detach screen connector.
    • Remove four screws (5.8 mm) located at hinges of the screen.
    • Lift and remove display screen.
Conclusione
May Chauvin
Membro da: 14/04/2011
186 Reputazione
6 Guide realizzate
Cal Poly, Team 12-34, Maness Spring 2011 Membro di Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Membri
6 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,792
