Salta al contenuto principale
Dell Inspiron 5100 PP07L Memory Replacement
Cosa ti serve
  1. Dell Inspiron 5100 PP07L Memory Replacement, Revealing the memory panel: passo 1, immagine 1 di 1
    • Flip the laptop on it's back, so that the bottom is facing up.
  2. Dell Inspiron 5100 PP07L Memory Replacement, Screw Removal: passo 2, immagine 1 di 1
    • Loosen the single Phillips #1 screw.
    • This screw is attached to the panel and cannot be removed.
  3. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: passo 3, immagine 1 di 3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: passo 3, immagine 2 di 3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: passo 3, immagine 3 di 3
    • Push the highlighted pin outward until the RAM pops slightly out of its socket.
    • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
    • Not seating the new DIMMs correctly could cause the device to refuse to POST.
Conclusione
Altre 2 persone hanno completato questa guida.
May Chauvin
Membro da: 04/14/11
201 Reputazione
6 Guide realizzate
Cal Poly, Team 12-34, Maness Spring 2011 Membro di Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 4,504
